Powermac G5 recording audio
    sabbate
    Posts: 110 from 2013/7/7
    but there is a possibility to record music with a powermac g5, I have a sb live but I think it can not be installed in slots pcx?
    hi all
  • »01.02.15 - 11:09
    deez
    Posts: 53 from 2003/5/28
    hi all
    No recording on G5 bulit-in audio.
    But insert SB Live! in PCI slot G5 :)
  • »01.02.15 - 11:45
    sabbate
    I do not have pci slots only pci-x
    [ Edited by sabbate 01.02.2015 - 15:02 ]
  • »01.02.15 - 11:55
    Posts: 12557 from 2003/5/22
    If the card is a universal one (3.3V/5V) it can be used in a PCI-X slot.
    http://upload.wikimedia.org/wikipedia/commons/1/15/PCI_Keying.svg
  • »01.02.15 - 18:40
    sabbate
    I understand thanks
  • »02.02.15 - 09:40
    sabbate
    is not universal is 5 v
  • »02.02.15 - 09:48
    sabbate
    thanks for the advice now I bought a compatible sb live so I can make music with my G5
    hi all
  • »09.02.15 - 13:33
    Posts: 1390 from 2010/1/6
    Please would you tell us your experience with that card....(I'm also interessted to by one...)
  • »09.02.15 - 15:59
    Posts: 1095 from 2004/9/23
    I bought one for testing last year (50 cent on flea market). Works fine, but I did not try recording.
  • »09.02.15 - 16:11
    sabbate
    I have not tried to record cmq should go at least programs like hd-rec and audioevolution work without any problem
  • »09.02.15 - 18:26
    sabbate
    I tried to record something with either hd-rec audioevolution that works with everything
    hi
  • »15.02.15 - 10:37
    Very fine! Thank you.
  • »15.02.15 - 14:06
    WB_Coder
    Posts: 66 from 2014/5/1
    hi
    Now that you have confirmed that recording works on your SB Live audio card, do you mind telling us which software you use the most for all of your audio work? Which audio programs work best on MorphOS. Have you tried Bars & Pipes, or is that only ported to AmigaOS4.x as a native PPC program? Does anyone use the 68k version of Bars & Pipes on MorphOS?
    WB_Coder = Wanna Be Coder
  • »16.02.15 - 19:04
    sabbate
    use hd-rec works very well is the most complete audioevolution but what about the midi currently do not use it, however hd-rec has an excellent implementation midi strongly urge you to use this software
    hi
  • »17.02.15 - 14:09
