Overclocking Voodoo3 3000
    Tcheko
    Posts: 540 from 2003/2/25
    Hello,
    Do someone know about oc'ing a voodoo 3 3000 graphics board?
    I know that this board can be overclocked with software settings (key registry with windows).
    Does CGX offer a software way to oc Voodoo boards?
    Regards,
    Tcheko
  • »03.03.04 - 11:36
    Miky060
    Posts: 694 from 2003/2/24
    I'm sure it is possible:Idid it on my Amiga underPcasso96. I also overclocked te BVision under CGX.
    Now the problem is to get the correct tooltype for the Voodoo under CGX. Ask Henes, Bigfoot,or Frank to have it and start to pray :-)
  • »03.03.04 - 12:37
