Highest possible resolution
    Yasu
    Posts: 1724 from 2012/3/22
    What is the highest possible resolution MorphOS can support? Does it handle 4K if the gfx card is good enough?
    My MorphOS blog
  • »25.01.15 - 20:35
    TheMagicM
    Posts: 1220 from 2003/6/17
    I dont know if its just me...even if I run a huge resolution, I dont see much of a difference. Well, its a bigger res..but... Ie. 640x480 on an original Amiga vs switching to a bigger resolution made everything smaller and gave alot of desktop real-estate like if you switched to interlaced or using a cybergraphix card and jumping to a different res.
  • »25.01.15 - 22:21
    Posts: 1077 from 2004/9/23
    As far as I remember MorphOS supports resolutions up to 2560x1600 with dual-dvi mode.
    This requires some better GFX card. AFAIR Raden 9600 and better.
    MorphOS itself should be able to deal with 4k screens, but 4k displays are currently not possible due the lack of more advanced graphic cards able to deal with it.
    [ Edited by geit 26.01.2015 - 01:40 ]
  • »25.01.15 - 22:38
    Posts: 2555 from 2003/2/24
    To be precise:
    You need the 9650 with 256MB as the normal 9600s only have single link DVI.
  • »26.01.15 - 14:27
    connor
    Posts: 650 from 2007/7/29
    although you answered to it it seems you forgot about https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=11041&forum=3 :-)
  • »27.01.15 - 17:30
    Yasu
    @connor
    Silly me, I did forget about that thread :-p
    I have a DualDVI on my X800. I'm curious now if I can get a resolution beyond 1920x1200 on my monitor now :-)
    My MorphOS blog
  • »27.01.15 - 21:32
    Posts: 1 from 2015/1/31
    Is there a NFS Client for MorphOS ?
    I found one but it is with a TCP program and I don“t understand because MorphOS have already a TCP/IP Stack !?!
    ___________
    70-680
    [ Edited by Atifrazaa 31.01.2015 - 07:17 ]
  • »31.01.15 - 05:16
