G4 battery
    NicePics13
    Posts: 63 from 2007/3/9
    For some reason my new oldstock 4400mAh battery is detected as a 5610mAh one in both MorphOS and OS X :-P
    So as soon I get the low battery warning somewhere below 30% it is essentially at 0% already. Quite annoying.
    Anything that can be done or should I just get a spare?
    CBM Amiga 1200 + 4MB AMITEK with 33MHz 68882 FPU
    PowerBook5,4 1024MB 1333MHz G4
  • »19.01.15 - 09:58
    Posts: 1073 from 2004/9/23
    If the system turns off automatically.
    Close the lid and charge it without opening it, using it or cutting the power until charging is 100% done.
    That should calibrate it. If not your battery is not compatible or broken and you need to live with it.
    Geit
    [ Edited by geit 19.01.2015 - 13:42 ]
  • »19.01.15 - 10:40
    NicePics13
    Thanks.
  • »19.01.15 - 13:13
