ipod support
    bash64
    Posts: 972 from 2010/10/28
    Aminet has a music player called Tunenet that has an ipod nano plugin to decrypt m4a files.
    Any MOS music player with the same ability out there?
  • »09.01.15 - 20:25
    clr666
    Posts: 86 from 2008/7/8
    I prefer Rockbox firmware for my ipod's becouse there is no need proprietary sync software (mounts in MorphOS like any other MSD device), and much more formats supported.
    _______________
    wintel free
  • »10.01.15 - 06:17
    Cego
    Posts: 738 from 2006/5/27
    mplayer can play m4a files, but i had always 100% cpu usage...
  • »10.01.15 - 08:52
    Cego
    check this topic:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=9946&forum=9#114004
  • »10.01.15 - 08:54
