wifi reveiver
    amiga4001
    Posts: 454 from 2006/11/16
    I want to use a powerbook for using it with aminetradio as a internetradio on my work.
    There is a free wifisignal but it's not strong enough,sometimes it works ok but often the radio stalls cause off the weak signal.
    Is there a device which I can with a better antenna?
    All I can find are devices with a usb connection,I need a standalone device with lan ports I guess.
    Any tips?
  • »07.01.15 - 04:53
    catohagen
    Posts: 297 from 2003/5/20
    You can use any router that can be configured as a client or client bridge, I used a TP-Link TL-WR703N with dd-wrt firmware on it, its cheap and very small, powered by a usb cable and connects with a 100mbit ethernet plug.
  • »07.01.15 - 05:02
    Posts: 2209 from 2003/2/24
    I'm getting much better connection with Atheros 5xxx based Cardbus card than with internal card/antenna on Powerbook. So, I can recommend to try that kind of option too, if you don't want that much extra stuff on the desk.
  • »07.01.15 - 05:38
    clr666
    Posts: 86 from 2008/7/8
    I am using on my work TP-Link TR-ML 3020
    It's very tiny thing, also capable 3G/4G connection via USB modem. Device now retranslate public hotspot from street to our office :)
    _______________
    wintel free
  • »07.01.15 - 08:26
    amiga4001
    So any router set up as client will do.
    Guessing I'll have most luck with one which has a better antenna?
    Or should I look for one on which I can connect an external antenna?
    This TP link model seems like a nice device but it has no external antenna.
    No need for an expensive thing may be an old used one...
  • »07.01.15 - 18:37
    Posts: 2082 from 2003/6/4
    Read jPVs suggestion. I too have good experience with an Atheros5000 Cardbus device. With the inbuild airport adapter WLAN was pretty weak, but with the Atheros card (in my case a card by Netgear) WLAN works rather well.
  • »07.01.15 - 19:39
    clr666
    I have another question. How today i can listen internet radio with anr? I remember sort of proxyes in settings, but how actual settings right now?
    _______________
    wintel free
  • »07.01.15 - 22:02
    Posts: 1376 from 2010/1/6
    Load a playlist with URL of radiostation to ANR.....
    Example (copy it to a text-file and load it to ANR):
    [playlist]
    numberofentries=4
    File1=http://205.164.41.18:7040
    Title1=(#1 - 16/500) 1.FM - BLUES RADIO
    Length1=-1
    File2=http://205.164.62.21:7040
    Title2=(#2 - 65/1000) 1.FM - BLUES RADIO
    Length2=-1
    File3=http://205.164.62.13:7040
    Title3=(#3 - 73/1000) 1.FM - BLUES RADIO
    Length3=-1
    File4=http://72.13.83.84:7040
    Title4=(#4 - 4/12) 1.FM - BLUES RADIO
    Length4=-1
    Version=2
  • »08.01.15 - 13:18
