Moderator
Posts: 2564 from 2003/2/24
PC cards don't work on Macs and vice versa unless falshed with a suitable ROM (actually there are a few Radeons with Dual-ROMs but thats not the point).
While flashing your 8500 might be possible you might still run into troubles:
- MorphOS did have some probs working with reflashed cards in Mac
- a 8500 is pretty low end
Best option is IMO to check ebay for genuine Mac Radeon pulled from G5s, those come as 9600 and bigger an with up to 256MB. Basic 64MB 9600 should be found for 20Euro or even less.
