WiFi -> System freeze
    Cego
    Posts: 738 from 2006/5/27
    Hi there,
    it seems that i have a lot of trouble with morphos lately. On my G5 printing doesnt work, now on my Powerbook i have another problem with my WiFi.
    As soon as i connect to my WiFI with the built in Airport card the whole system freezes. Just because of that i've bought a Atheros based PCMCIA card. Now when i connect with that card, the system prefs will freeze.
    I also tried that on a clean install. Same symptoms. Somebody any ideas?
  • »18.09.14 - 17:39
    Cego
    i have to say that internal WiFi did work earlier at my parents house and when i was in vacation. but that was more or less buggy. i had pretty bad signal, even though the router was 2 meters away.
  • »18.09.14 - 17:40
    Cego
    ok, i could narrow it down to my modem->repeater setup. as soon as i deactivate WDS in my router and switch off my repeater WiFi will work. Right now i'm typing from my Powerbook. So it seems that morphos has trouble with repeater setups. Maybe the devs could fix this?
  • »19.09.14 - 06:26
    catohagen
    Posts: 297 from 2003/5/20
    it worked before with repeater ?
  • »19.09.14 - 07:09
    Cego
    no, this was my first attempt
  • »19.09.14 - 07:20
    Cego
    maybe some morphos dev could say something regarding this issue? are there any other users with the same setup, who could check this?
  • »27.09.14 - 07:05
    Posts: 1521 from 2003/2/24
    Can you get debug log from the system prefs freeze?
  • »27.09.14 - 08:01
    Cego
    @itix
    there is no debug log output at all when the freeze happens.
  • »03.10.14 - 12:40
