Atheros 5k MorphOS wifi support
    Posts: 12557 from 2003/5/22
    > MorphOS 3.6 will be released in this year?
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=11&topic_id=8931&start=106
  • »20.04.14 - 11:05
    stephen_robinson
    Posts: 746 from 2007/4/22
    Still haven't sobered up enough to check the others, but my Unsupported Quad G5 2.5's apple own wireless network card is:
    Wireless Card Type: AirPort Extreme (0x14E4, 0x4318)
    Wireless Card Locale: Unknown
    Wireless Card Firmware Version: Broadcom BCM43xx 1.0 (4.170.25.8)
    So another good reason to support them...
    Just sayin'
  • »21.04.14 - 15:03
    diezi7
    Posts: 167 from 2005/7/25
    Hi guys,
    I'm willing to know about wifi cards cause my PowerMac
    does not accept one Airport Extreme card I've got here lying
    around (MDD FW400).
    Do any of the mentioned cards work over the
    PCMCIA slot on PowerMac G4.
    Are Airport cards supported? (not extreme)
    Would a PCI Wifi card Airport compatible be recognized and work?
    And too, if there's some concrete model of PCI Wifi card working fine.
    Thx
    Pegasos II G4 (not working)
    Powerbook G4 1.0 15"
  • »01.10.14 - 08:03
    > Do any of the mentioned cards work over the PCMCIA slot on PowerMac G4.
    See comment #23 in this thread.
    No.
    See that thread:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=6042&forum=11
    This thread has several examples.
  • »01.10.14 - 10:57
    diezi7
    This thread has several examples.[/quote]
    Thanks for the help.
  • »01.10.14 - 19:12
