Info in startup screen
    Tomo
    Posts: 93 from 2003/7/29
    When I start up my PEG2 there is just after the morphos-logo and before ambient a very short message.
    Too short to read. (but I just can read that the words 'fail' and 'vector' are in the message).
    Is there a way to recall that message?
    Everything works fine, except Muibase, if a make a compex database it freezes (only Muibase). Is there a connection?
    Regards Tom
  • »17.09.14 - 15:32
    igracki
    Posts: 469 from 2003/2/24
    You could try to record a video with your mobile phone, and then play it with mplayer frame by frame.
  • »17.09.14 - 15:44
    Posts: 1090 from 2004/9/23
    Open an editor and add
    set echo on
    as first line of the file S:user-startup.
    now reboot. The message should stay visible.
    You may need to iconify the shell to finish booting. Afterwards remove the problem and the line again.
    Geit
  • »17.09.14 - 16:53
    Tomo
    @ geit: the command doesn't work. I put it in the user-startup and I can see that it gives more output but I still have just a fraction of a second time to read before ambient appears and then the messages are 'whipped out'.
    @igraki: I tried also your suggestion, but i can't get the letters sharp enough to read
    regards Tom
  • »18.09.14 - 10:59
    Posts: 1354 from 2004/2/8
    I would reccomend running SFS Doctor and checking your HDD partitions.
  • »18.09.14 - 12:01
    Tomo
    Done. Everything is fine....
    Regards, Tom
  • »18.09.14 - 15:02
    regards Tom
    Use an editor and open SYS:MorphOS/s/startup-sequence
    add a colon ";" before the EndCLI >NIL: line at the bottom This will prevent the shell from closing.
    Geit
  • »18.09.14 - 16:57
    Tomo
    Oke, the last hint worked for me. I sorted a lot of wrong assigns out. Still left:
    CheckMount: Globvec 1 is not supported. Only -3, -2 and -1 are supported here
    EXECUTE: Can't open "GG:sys/S/gg-startup"
    object not found
    I have looked into that folder of GG... and found only 2 files"
    'resident_gg' and 'unresident_gg'.
    I can't find gg-startup.
    With many thanks, Tom
  • »18.09.14 - 18:20
    No clue about the first one, beside there is no GG:Sys/s/gg-startup here, too
    For the second one check the SYS:Devs/DOSDrivers drawer. You have installed a mountfile which uses "globvec = 1" in it, which is not supported by the mount command as the message states.
    Probably removing that line from file is enough to fix the issue.
    Geit
  • »19.09.14 - 00:20
  • HAK
    Posts: 225 from 2003/2/24
    object not found
    Hehe, that's leftover stuff from the OLD SDK.
    (I checked and found my last traces in backups between MorphOS 2.5 and 2.6)
    And this is really in MOSSYS:s/startup-sequence? It should have been put in S:user-startup back then.
    If it is in MOSSYS:s/startup-sequence, you'd better check with the one on the ISOs. Normally this file shouldn't be changed at all and any changes should go to S:user-startup.
    Bye HAK
  • »19.09.14 - 12:00
    Tomo
    I found 'globvec = 1' in a CON-file. It is no removed...
    I also removed the gg... assign.
    Many many thanks for you help
    Reagrds, Tom
  • »19.09.14 - 12:57
    Tomo
    sorry I thought I had allready given a reaction on the last suggetions.
    I cleaned 'Devs/DOSDrivers' ( I think from an old installation) and now everything is fine. Everybody thanks for helping me with suggestions.
    Regards Tom
  • »27.09.14 - 10:35
