Questions about powerbook
  • JJ
    JJ
    Posts: 147 from 2010/7/7
    Hi All,
    Been using MorphOS for awile now on a mac mini, but not spent much time on it for awhile.
    Just got myself a powerbook G4. All installed with morphOS and Mac OSx10.5 dual boot :)
    Two Quick questions(for now) that I hope somone can help me with.
    Loving have wirless at last on MorphOS :) :)
    1) I cannot seem to get the right click on the trackpad to work as a right click. How do I go about doing this ? Is there a way. I cannot find a specific option in prefs like u get on OSX.
    2) This is a longshot. Is there anyway of switching on and controlling the backlight on the keyboard.
    Thanks All
    We don't stop playing because we grow old; we grow old because we stop playing. - George Bernard Shaw
    Xbox Live: S0ulA55a551n2
  • »04.09.14 - 17:24
    Posts: 12557 from 2003/5/22
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=10140&forum=11
  • »04.09.14 - 17:30
  • JJ
    JJ
    Worked out backlight. Not sure how the post helps me though. Shift click is for one button mouse. Fairly sure the mouse on a PowerBook has right click also. Will double check now. Thanks
    Edit. I apologise seems it doesn't. Will jus use two finger gesture thanks for your help
    [ Edited by JJ 04.09.2014 - 17:59 ]
  • »04.09.14 - 17:56
    Posts: 3336 from 2003/3/5
    Did you check the Touchpad settings?
  • »12.09.14 - 05:04
  • Visitor
  • thanks for sharing...
  • »17.09.14 - 08:44
