Moderator
Posts: 2539 from 2003/2/24
a) make sure you only install the exact speed of CPUs as it orginally, anything else or just fitting 1 CPU will end in all fans running topspeed all the time
b) when you do have a matching set of CPUs you'll need to calibrate the system (requires some sort of Apple-diagnostics-CD, google might help) to stop all fans running topspeed all the time.
