MorphOS Developer
Posts: 1098 from 2004/9/23
I have a Powermac G5 with an AGP ATI Radeon 9800XT working well for most things. I wanted to install a secondary video card to do Warp3d stuff (since it's a very big reason I wanted to use MorphOS in the first place!) so I was able to pick up a Voodoo 3 2000 PCI card. I fitted the card, attached a monitor, and booted. The card was recognized during the MorphOS boot sequence and displayed the MorphOS boot logo. However, once Ambient loaded on my primary gpu/monitor, the voodoo stayed on the boot logo. I tried running some games on that monitor by choosing the gfx/monitor combo at game launch which always resulted in a frozen computer - the strange thing is that the monitor would change to an all black screen before freezing.
Did you try using normal MUI applications on that screen? To do that you need to define a screen using the voodoo. After doing that you can move any application to the secondary screen and even move the mouse over.
However, when it comes to gaming there are a big issues with using the voodoo. The GFX mem ist quite low and your screen is probably not 640x480, so you run out of gfx memory very quickly. I am using a voodoo in my G4 and it is nice as secondary screen, but when it comes to playing videos or games fun is over quite soon, especially I am using a 1440x900 screen in 16 bit.
Since your card is showing the boot image, it is working fine with MorphOS. The voodoo is just not the card you want to use for 3D.
The only way out would be fixing the need of using different cards, so you could use a Radeon 9200 PCI. Until then it is best to forget about that for just a hand full of games.
BTW: WipEout works even better in FPSE using the PSX game, than using the "real" port.
Geit
