Powerbook Display defect
    Cego
    Posts: 738 from 2006/5/27
    Hi there,
    my powerbook did arrive today and to my suprize the display is kinda broken.
    Look at the pics. Now i wanted to ask if it is possible to fix this. I have the feeling that this is only the beginning. Sooner or later the display will be completely broken.
  • »04.08.14 - 08:42
    Jeckel
    Posts: 133 from 2007/3/11
    It looks like dead pixels.
    It should be stable; might be due to some bad pressure at some moment.
    Anyway, you can replace the LCD panel easly:
    https://fr.ifixit.com/Guide/PowerBook+G4+Aluminum+15-Inch+1.5-1.67+GHz+LCD+Replacement/4251
  • »04.08.14 - 12:49
    Posts: 2532 from 2003/2/24
    Easily ????? WTF ?????
    There is hardly any PB fix that is harder ( just ask ThePlayer....).
  • »04.08.14 - 12:56
    Cego
    I will try to reverse the transaction and send it back to the seller and get my money back. This is hardly repairable and i wouldn't have bought it, if the seller had told me. Selling will be impossible without losing a lot money, because the machine already had a MOS Key.
    I hope everything goes well.
  • »04.08.14 - 14:07
    Jeckel
    Don't worry. The pictures might look terrific but it is really easy!
    I did it twice; it's a matter of 20 minutes.
    [ Edited by Jeckel 04.08.2014 - 17:04 ]
  • »04.08.14 - 16:03
    Cego
    I dont think that this is a dead pixel problem. Looks more like liquid damage to the inside of the front display layer.
    I dont have the money to change the display or the knowledge to do so. The machine was sold as "no visible damage" except for some minor bumps at the case, which were clearly seen on the pics i got, before buying.
  • »04.08.14 - 16:26
