Choice of SATA HDD
    Yasu
    Posts: 1724 from 2012/3/22
    I want to buy a terrabyte HDD for my Powermac G5. Is there anything I have to keep in mind when buying one or will any SATA do?
    My MorphOS blog
  • »30.09.13 - 11:21
    SoundSquare
    Posts: 1214 from 2004/12/1
    any SATA hard drive should be ok, but keep in mind that a SATA3 drive won't get any close to SATA 3 speeds, SATA 3 drives have to be configured in SATA 2 mode (usually it has a jumper on it to set it up ) for the G5. So make sure there's such a jumper on the drive.
    SSDs are a bit more tricky, some SATA 3 SDDs won't work, some will. Only all SATA2 SSDs should be ok (hard to find now).
    SATA 3 = 6Gbit/s
    SATA 2 = 3Gbit/s
    [ Edited by SoundSquare 30.09.2013 - 16:12 ]
  • »30.09.13 - 12:09
    Yasu
    So if I don't set the jumper correctly or it missen one it won't work?
    My MorphOS blog
  • »30.09.13 - 12:27
    SoundSquare
    the best way for you not to get an unsupported one would be to google for the model(s) you can get and powermac g5 compatibility. All information i just gave you comes from googling.
  • »30.09.13 - 13:04
    Yasu
    I have plenty of bad experiences of trying to do these kind of things without informed help. So I prefer to listen to other peoples recommendations.
    I was able to connect an external USB HDD and read it without problem. Does that mean that I can use that HDD in my G5 or only via USB?
    My MorphOS blog
  • »30.09.13 - 13:36
    Intuition
    Posts: 1116 from 2013/5/24
    This should work fine.
    http://viewitem.eim.ebay.se/NEW-Massive-1000GB-1TB-SATA-II-35-INTERNAL-DESKTOP-HARD-DRIVE-/121148514861/item
    Remember to install IceFS if you want one contiguous 1TB partition.
    [ Edited by Intuition 30.09.2013 - 19:23 ]
  • »30.09.13 - 16:18
    Yasu
    I don't mind having plenty of partitions as long as everything works.
    [ Edited by Yasu 30.09.2013 - 20:33 ]
    My MorphOS blog
  • »30.09.13 - 16:31
    Intuition
    IIRC PFS3 has a max partition size of 128GB, not sure about SFS.
  • »30.09.13 - 17:22
    Posts: 1932 from 2003/10/19
    I cant get a lot of them but I can purchase Intel SSD at an employee discount. Most are 50% off what normal people have to pay. Let me know the model you want and I can look it up at work and see what I can do for you if you want one.
  • »02.10.13 - 12:00
    nemesiswar
    Posts: 37 from 2012/11/12
    I have read recommandations of Intel 320 series should be the best choice of SSD for a Pmac G5.
    @Yasu go to Kjell & company and ask for a SATA I compatible 1TB hardrive.
    Power Mac G5 2,0 Ghz registred
    IBook G4 1,2 Ghz registered
    Mac mini G4 1,5 Ghz unregistred
    Power Mac G5 Quad awaiting support
  • »04.10.13 - 13:20
    connor
    Posts: 650 from 2007/7/29
    http://en.wikipedia.org/wiki/Smart_File_System
  • »04.10.13 - 13:25
    Yasu
    Thanks for all the advise! Right now I'm thinking of using one of my older 1 TB USB HDD that MOS reads without problem and use them instead. The reason is so I can use the same HDD on my various MOS systems.
    If MOS can read NTFS via USB, does that also mean that it should be able to format it in a MOS friendly file system? Or does reading it tell me nothing about that posibility?
    How much faster is SSD on MOS really? That Windows is faster is given since it's just pure sh!t :-D
    My MorphOS blog
  • »04.10.13 - 15:06
    Posts: 2209 from 2003/2/24
    PFS3 has limit of 104GB and SFS has 128GB.
  • »04.10.13 - 15:39
    Yasu
    @Ascii
    Can you still get SSD:s with a discount? :-)
    My MorphOS blog
  • »24.07.14 - 08:41
