Posts: 72 from 2011/11/18
Chain-Q schrieb:
Did you use any WiFi card with 3.5 before?
Yes, a PCMCIA NEC WarpStar.
Since the WiFi driver is the only driver area where MorphOS 3.6 has really big changes, you can try to disable WiFi (in network prefs, untick the wl0 interface) and see what happens.
You are right. I disabled the wl0 device and used again my wl1 (atheros) device. Now the system doesnt freeze anymore. :)
But why?
Is the new wifi driver unstable?
Maybe some conflicting old settings? How can I cleanup these settings (kinda factory reset)?
