building a reliable strong wifi network
    amiga4001
    Posts: 454 from 2006/11/16
    Hello All,
    I have a router which doesn't provide enough signalstrength to get a good wifi signal on the attic,yard etc.
    So I purchased me a enginius ecb300 which I connected onto the router with a network cable.
    The idea was to get a second network (SSID) with dhcp handling.
    The original router also uses dhcp handling.
    This works but speed is not good if I use the enginius network,also connection loss...
    Should I setup the enginius network with static ip?
    Signalstrength of the eginius is very good,much stronger then original router.
    I took this route as I found out the repeaters commonly used loose speed and as I don't have a very speedy internet connection.
    Hoping for some advice?
  • »06.07.14 - 04:50
    nemesiswar
    Posts: 37 from 2012/11/12
    Iam using a airport express to extend my Wifi. Works like a charm.
    Power Mac G5 2,0 Ghz registred
    IBook G4 1,2 Ghz registered
    Mac mini G4 1,5 Ghz unregistred
    Power Mac G5 Quad awaiting support
  • »06.07.14 - 06:55
    boot_wb
    Posts: 874 from 2007/4/9
    amiga4001 wrote:
    Hello All,
    You could try limiting the Enginius to operate in wireless G mode rather than B/G/N, might be trying to negotiate a faster line speed or something.
    What do you mean by 'connection loss': Losing network connection, or just delayed page loading?
    If losing connection, is it constant reconnection/dropping of the network every few seconds, or losing network connection every few minutes, or just losing connection occasionally (eg a couple of times an hour)?
    By 'speed is not good' do you mean a constant but slow transfer speed, or do you have connections which take a long time to get going (look at the connection lamps at the bottom right of Odyssey) whilst a page is loading?
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »06.07.14 - 12:56
    Posts: 2082 from 2003/6/4
    amiga4001 schrieb:
    Hello All,
    Repeaters halve the _maximum_ speed. But if internet connection is way below your network speed (it probably is) then this halving of max speed does not matter. I have a repeater and internet speed is as good as nearby the router without the repeater.
  • »06.07.14 - 17:51
    amiga4001
    With the enginius connection I have lot's off red lights with owb.
    Also connection is ok for say 10 minutes then connection is gone and I have to do a reboot the get a new connection.
    With slow I mean slow loading off pages,downloads etc..
    I'll try the G way If I can figure out how to set the enginius up.
    Maybe I am beter off with a repeater but I must say the enginius puts out a very strong signal,don't like to let it go.
  • »06.07.14 - 18:22
    Intuition
    Posts: 1116 from 2013/5/24
    Would it not be simpler to just buy a better router?
  • »06.07.14 - 23:47
    amiga4001
    I did try to change the router.
    As I have no experience in these ip equipment I figured i'm better off in a real shop.
    I asked the salesman for advice.
    He advised me to not buy a router as the settings off the original router are set by my provider and not easy to setup yourself.
    He also told me only companies buy a router and do the settings themself.
    I am on adsl.
    This is why I went the enginius way..
  • »07.07.14 - 17:03
