Click on touchpad or USB Mouse won't work..
    matt3
    Posts: 785 from 2004/2/10
    My Powerbook recently will not allow any right clicks on either the touchpad or a usb mouse.
    Left clicking highlights and sometimes allows you to move a desktop item but will not load items.
    Mouse movement with touchpad or usb mouse works.
    Any help is appreciated...
  • »05.07.14 - 11:16
    Posts: 3336 from 2003/3/5
    Sounds as if one of your keyboard keys like alt or shift were stuck.
  • »05.07.14 - 12:08
    matt3
    Seems like sfs is the culprit. Really strange.
    I can boot from a MOS CD and all works well, if I boot from the SSD in the PB the mouse and touchpad dont work.
    I couldn't update MOS over it because of SFS errors.
    I will backup my data and reinstall MOS.
    Does it make sense to reformat SFS since 3.6 increased it's capability?
    Should I even bother with icefs since sfs can save large files now?
    Matt
    [ Edited by matt3 05.07.2014 - 10:21 ]
  • »05.07.14 - 13:20
    Posts: 12557 from 2003/5/22
    SFS is still restricted to max. 4 GiB file size, which IceFS isn't.
  • »05.07.14 - 16:36
