usb 2.0 board?
    sabbate
    Posts: 110 from 2013/7/7
    hi all
    I installed a card with chip away poseidon recognizes but my devices are not recognized, maybe the card is not working properly?
    which model I could install?
    thanks
  • »10.06.14 - 10:00
    sabbate
    This might be fine?
    http://www.macshop.it/comunicazione/interfacce-firewire-e-usb/sonnet-allegro-pci-usb2.html
    hi
  • »10.06.14 - 10:10
    Posts: 3311 from 2003/3/5
    Which devices fail exactly?
    There's no need for you to buy overpriced Sonnet cards. A regular card based on a NEC chip will work just fine.
  • »10.06.14 - 11:29
    sabbate
    ok thanks
  • »10.06.14 - 13:21
    Posts: 1932 from 2003/10/19
    Yup, i got myself a 6 port $8 Chinese card online with an NEC chip that works great.
  • »10.06.14 - 20:23
    sabbate
    ok hi acill
  • »11.06.14 - 10:23
    sabbate
    What could I buy, I bought one but it does not work
  • »18.06.14 - 09:58
    Posts: 1090 from 2004/9/23
    The easiest way to fix this is to delete "SYS:Prefs/env-archive/sys/Poseidon.prefs" and reboot.
    Geit
  • »18.06.14 - 12:54
    sabbate
    with the usb card inserted does not start even morphos
  • »18.06.14 - 13:50
    Posts: 2564 from 2003/2/24
    Even after deleteing that file ?
  • »18.06.14 - 14:06
    sabbate
    no
  • »18.06.14 - 15:11
    sabbate
    I did not delete the files on your computer with the card will not start
  • »18.06.14 - 15:12
    sabbate
    morphos should also support chip away in fact my card is recognized and also the coupling device that, at least from this I infer preferences of Poseidon. Only that the external hd is not seen in the desk ...
    you have any idea about it!
    hi all
  • »21.06.14 - 17:41
    Since you've allready have obvious PCI-issues as shown in other threads, you should try what happens when you strip down the system to an AGP-card and 1 PCI at a time.
    If a card still makes problems than, throw it away and afterwards continue trying to find a combination of cards that actually works.
  • »21.06.14 - 18:58
    sabbate
    the only card that I work correctly sb live.
  • »22.06.14 - 16:26
    Is this a G5? PCI in G5 may not work properly with MorphOS 3.5.
  • »22.06.14 - 20:15
    Posts: 12536 from 2003/5/22
    That would be disappointing, especially as the 3.4 release notes read:
    "Fixed several firmware related problems that prevented some PCI cards from working properly on G5 machines."
    http://www.morphos-team.net/releasenotes/3.4
  • »23.06.14 - 04:43
    Oh, heh. Seems I remembered it wrong, then. :)
    Geit
  • »23.06.14 - 08:22
