dual monitor?
    sabbate
    Posts: 110 from 2013/7/7
    hi
    I installed a pci graphics card I could use another monitor then a total of two since I have another graphics card agp slot
    thanks hi
  • »19.06.14 - 09:49
    Posts: 1090 from 2004/9/23
    Yes, but currently only when the cards are different. e.g. a voodoo and a radeon due a limitation within the gfx drivers AFAIK.
    I use a Radeon9000 and a Voodoo3 in my PowerMac 933 and it works fine. I can even move the mouse pointer between screen as you would expect.
    [ Edited by geit 19.06.2014 - 11:21 ]
  • »19.06.14 - 10:20
    sabbate
    I would have problems with any two radeon graphics cards installed Precisely so.
  • »19.06.14 - 14:08
    sabbate
    when the monitor is connected to the pci card and start a music player the monitor goes into standby.
    i have ati rage pro agp and radeon 7000 pci
  • »19.06.14 - 14:18
