PB 5,9: battery seems faulty...
    igracki
    Posts: 468 from 2003/2/24
    I get this message in the Energy Information window, I calibrated the akku (let MorphOS running till it shuts down, then load the akku while Powerbook is off) already two times, but I still get this message!
    I have the original power adapter with 65W.
    The akku last about 3,5 hours.
  • »25.05.14 - 15:28
    Posts: 3274 from 2003/3/5
    Calibration has nothing to do with this. This is displayed when you battery readouts become bad randomly. Pretty common with 3rd party or reset batteries.
  • »26.05.14 - 04:25
    igracki
    so nothing to worry about?
    How do I know if the battery is 3rd party or reseted?
    Here is a picture of the battery.
  • »26.05.14 - 08:38
    An original battery would have a (C)(TM)(etc) Apple. The link you posted is to a 3rd party battery.
  • »26.05.14 - 10:24
    igracki
    ok, thanks!
  • »26.05.14 - 11:30
