Using PS3 Controller?
    XDelusion
    Posts: 602 from 2010/10/27
    I read that a few people in these forums were using PS3 controllers with MorphOS. That is to say, if I read correctly.
    The problem I am running into is that I plug it in, Trident detects it, but when I go to test the buttons, direction pad, and analog, they all act as if they are non-functioning.
    I also tried it under Win 7 64-bit, and it detected it automatically without the need for additional drivers, but once again, it did not respond when testing.
    Could the joystick be bad, or am I missing something?
    Thanks in advance!
  • »13.04.14 - 22:59
    hooligan
    Posts: 1948 from 2003/2/23
    Try Motion In Joy. The pad you're using is faultless.
  • »14.04.14 - 02:16
    Posts: 12557 from 2003/5/22
    I read it differently:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=9781&forum=11&start=3
  • »14.04.14 - 05:38
    Posts: 3336 from 2003/3/5
    If you want a nice - and wireless ! - controller, get the Xbox360 PC adapter & pad.
  • »14.04.14 - 09:57
    igracki
    Posts: 471 from 2003/2/24
    Does this universal adapter is working on MorphOS to use a PS3 controler with the xbox driver?
    You can connect a PS3 controler to xbox/pc and XBox controler to a PS3 with it.
  • »14.04.14 - 11:22
    Afair it worked with a similar adapter henes has...
  • »14.04.14 - 12:17
