Support for PCMCIA CDROM?
    metatron
    Posts: 72 from 2011/11/18
    Does MOS support PCMCIA 16bit ATAPI CD-ROM controller?
    I plugged a Targa CD-ROM controller into my Powerbook 5.9. The CD spins up, but no icon is showing.
    Must I mount this drive specially or is it not supported in morphOs 3.5?
    [ Editiert durch metatron 05.04.2014 - 19:06 ]
  • »05.04.14 - 15:05
    Posts: 2564 from 2003/2/24
    Not supported.
    Try internal or USB.
  • »05.04.14 - 16:26
