Network problem PowerMac G5 2.7 Ghz
    AMike
    Posts: 15 from 2013/10/4
    Since the update from 3.2 to 3.3 I've a strange problem with my PowerMac - most of the time I get no internet connection after starting the machine - I've to reboot the Mac for 3 to 6 times to get the machine online. If I have managed to get online the PowerMac stays reliable online till to the next reboot - after a reboot the procedure begins from the start. When I boot OSX I'm always immediately online - every time - multiple tested. I've already changed the networkcable - any suggestion for this problem???
    PowerMac G5 2.7 Ghz 1GB RAM, Radeon 9800pro, MorphOS 3.5.1 registered with ChrysalisPack - dualboot with OSX.
  • »24.03.14 - 14:47
    boot_wb
    Posts: 874 from 2007/4/9
    Hi AMike,
    It may be a failure to get a network address using DHCP - have you tried setting a static network address?
    You will need to know your router's IP address (eg 192.168.0.1), and an available
    IP address to use for your MorphOS system (eg 192.168.0.101).
    RMB on desktop>Settings>System..>Network
    In the Network Interfaces tab:
    Ensure the checkbox next to the entry for your network connection is ticked (On mac-mini this is sungem_eth, Pegasos 2 rhinevia, blah, etc).
    Select the 'Static IP address' option button.
    Enter a valid IP address for your MorphOS system on your network (eg 192.168.0.101)
    Enter Subnet Mask (255.255.255.0)
    Enter the Gateway (your router) IP address (eg 192.168.0.1)
    In the Host and DNS tab:
    You must enter at least one, and up to 3 DNS server addresses.
    On a standard network, entering your router's IP address should be sufficient.
    [ Edited by boot_wb 24.03.2014 - 17:02 ]
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »24.03.14 - 16:02
