Is this compatible with MOS 3,2 ?
    Posts: 12536 from 2003/5/22
    > Still looking for an X1950 rom for G5 use. Haven't found one yet.
    I take it you have by now?
    http://www.amiga.org/forums/showpost.php?p=759797
  • »27.02.14 - 16:33
    No, I have both an X1900GT and an X1950XT.
    While I don't doubt you could flash the XT with the GT's rom, it would not perform optimally.
    Ur um, why do I feel like my German friends are stalking me?
    [ Edited by Jim 27.02.2014 - 19:51 ]
  • »27.02.14 - 18:50
    Seems I misunderstood your reply to rzookol then.
    Paranoia maybe? ;-)
  • »27.02.14 - 19:13
    Paranoia maybe? ;-)
    Guilt more likely.
    rzookol may have a card that looks like an X1950XT, the cooler on my second generation X1900GT looks exactly like an X1950XT cooler.
    They ditched the single wide "dust magnet" cooler for a more efficient double wide setup.
    If it had an X1900GT bios, that still might not affect the posted specs.
  • »27.02.14 - 22:12
    Posts: 2564 from 2003/2/24
    Paranoia maybe? ;-)
    Nah, more likely the misconception that he had any friends, German or not !
  • »28.02.14 - 09:52
    As I understand his statement he really has an X1950XT, flashed with an X1900GT PPC ROM. The WWW has some reports of people who say this is possible.
  • »28.02.14 - 10:46
    Yes, its possible.
    The 1950 is just a die shrink.
    But you would loose some performance.
    As I have an Apple X1900GT, and a PC X1950XT and X1900GT I'll get around to trying this eventually.
  • »28.02.14 - 19:41
    The R580 of the X1900GT and the R580+ of the X1950XT have the same die size. The shrinked die is the RV570 of the X1950GT and X1950PRO.
    http://en.wikipedia.org/wiki/List_of_AMD_graphics_processing_units#Radeon_R500_.28X1xxx.29_Series
  • »28.02.14 - 20:37
    BTW - Fug u Kronos,
    BTW - On further examination, the card I bought as an X1900GT would appear to be a flashed X1950XT, so that can be done.
    I might as well try this on the X1950XT I have on hand (and the PC X1900GT)
  • »28.02.14 - 23:41
