desktop case for peg2
    amiga4001
    Posts: 450 from 2006/11/16
    I am searching for a new case for my peg2.
    I have a Aopen g325 now ,but it is worn out and never actually liked it.
    What it should have is a cardreader build in and several usb ports on the front.
    Room for a dvd drive offcourse and like to keep it small so thinking about a desktop model.
    Any tips?
  • »22.02.14 - 04:48
    Jupp3
    Posts: 1193 from 2003/2/24
    Rather than that, you could buy one with front panel 3.5", there you can install any suitable card reader. I liked how my Antec Aria case came with built-it card reader... Until SDHC came around, and it wasn't compatible. Separate card reader I could have changed, but not that.
    Keep in mind that most cases with several USB ports simply have several cables to connect to the motherboard - which is generally a no-go with Pegasos 2. There MIGHT be some compatible USB2 cards, which instead of / in addition to back panel connectors would have several usb header connectors, or internal USB hubs, that allow "splitting" the one your card might have...
  • »22.02.14 - 17:18
    Many NEC USB 2.0 cards have an internal connector, but its a Standard USB socket not a pin header, so you need a card reader with a standard USB connector (not a header connector).
  • »22.02.14 - 21:31
