Wifi and Powerbook
    sonter
    Posts: 12 from 2012/6/24
    Newbie question here, sorry if this has been discussed elsewhere.
    I have a powerbook 5,7 and just installed morphos 3.2 cause I understand it added wifi support, but is the internal wifi card of the powerbook supported? i was not able to add it as a device. if i have to get a third party one, is there a list somewhere of supported devices ?
    thanks for any help :-o
  • »01.06.13 - 17:44
    Intuition
    Posts: 1116 from 2013/5/24
    Any Atheros 5000 based PCCard should work. I have a Netgear Wg511T and it works a treat at 108Mbps.
    See this thread for more.
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=9235&forum=11
  • »01.06.13 - 17:50
    sonter
    brilliant, thank you
  • »01.06.13 - 18:16
    bash64
    Posts: 977 from 2010/10/28
    just ordered a Netgear Wg511T.
    $925 shipped
    :-D
  • »01.06.13 - 20:20
    stephen_robinson
    Posts: 746 from 2007/4/22
    $925? Sounds a bit pricy.
  • »01.06.13 - 20:22
    bash64
    You know, it does.
  • »01.06.13 - 20:27
    Ingo
    Posts: 103 from 2004/3/19
    I bought one of those for 9,- Euro!  8-)
  • »01.06.13 - 20:31
    Intuition
    Ingo,
    That was a good bargain! :)
    I got mine free with a Netgear router years ago (2005/6 maybe) and haven't had any use for it until now.
  • »01.06.13 - 20:51
    Posts: 12557 from 2003/5/22
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=9235&forum=11&start=9
  • »01.06.13 - 22:59
    rebraist
    Posts: 96 from 2011/4/6
    Hi! I have a 5.6 powerbook with morphos 3.5 and a netgear wl511t.
    I was able to connect to a g wlan with wpa2, the semaphore goes green.
    But there was no way to connect to any site: "Error 6: Couldn't resolve host name"
    I had to change from dhcp to static ip (i have dhcp enabled and all tablets, smartphones and laptops in my house use dhcp) and it all worked fine.
    Sam440 Os4.1.6
    Aros-Aros-Aros.
  • »22.02.14 - 11:14
    Posts: 2577 from 2003/2/24
    DHCP has the tendency ton work when there is a reboot between setup and 1st use.
    Atleast thats the experience I make when I add a new WLAN to the list (known WLANs connect out of the box).
  • »22.02.14 - 11:23
