G5 PCI and PCI-X slots
    I just assumed so by the structure of Andreas' response.
    But PCI-X is little more than 133MHz 64 bit PCI so it probably would not be that much of a challenge.
    And the only cards we currently have support for are PCI.
    So that was the assumption I made, PCI cards in PCI-X slots.
  • »15.12.13 - 12:29
    BSzili
    Posts: 570 from 2012/6/8
    I mean to use a PCI card too (a WiFi one), but I have a 2.5 GHz June 2004 G5 model with only has PCI-X slots.
  • »15.12.13 - 12:53
    pampers
    Posts: 1071 from 2009/2/26
    So far I've tested SBLive and TP-Link TL-WN350G in my G5 2.7 - both works fine.
    MorphOS 3.x
  • »15.12.13 - 13:24
    Useful information.
    I guess I will pull my SB Live listing on eBay.
  • »15.12.13 - 13:29
    BSzili
    Awesome, I'm about to get a TL-WN551G for my G5 too. I already have one in my Pegasos II, and it works great in MorphOS.
  • »15.12.13 - 13:29
    What about the TL-WN350GD?
    Is that basically the same as the TL-WN350G?
  • »15.12.13 - 13:36
    pampers
    Yep, that's the model I have.
    MorphOS 3.x
  • »15.12.13 - 13:42
    BSzili
    The D in the name only denotes the detachable antenna. The MadWifi compatibility list can be used as a reference (the 802.11g cards): http://madwifi-project.org/wiki/Compatibility
    The MorphOS/AROS/AmigaOS4 driver uses the same Atheros HAL.
  • »15.12.13 - 13:47
    Posts: 12557 from 2003/5/22
    > What about the TL-WN350GD? Is that basically the same as the TL-WN350G?
    Yes.
    http://wikidevi.com/wiki/TP-LINK_TL-WN350G
    http://wikidevi.com/wiki/TP-LINK_TL-WN350GD
    Edit: Way too slow ;-)
    [ Edited by Andreas_Wolf 15.12.2013 - 15:48 ]
  • »15.12.13 - 13:47
    pampers
    Andreas_Wolf,
    Come on Andreas, are you getting old or just temporary internet issues? ;)
    MorphOS 3.x
  • »15.12.13 - 20:09
  • kjb
    kjb
    Posts: 6 from 2007/12/31
    Whether the TL-WN350G also works under osx ?
    Note, I use google translator
  • »30.01.14 - 19:05
  • vox
    vox
    Posts: 616 from 2003/11/24
    I seem to be only on topic, G5 end model is only PCI-E model until SAM460ex support.
    Which cards can be expected to be supported?
    I need to know since I want to buy LOW PROFILE card, expensive ones, to fit it into Lorianos
    X500 case now with MOS keys
    https://www.facebook.com/photo.php?fbid=245838068924760&set=a.114872455354656.20409.100004957059281&type=1&ref=notif¬if_t=like_tagged
    So, Radeon X1600, Radeon 4000HD, Radeon 6000-7000HD?
  • »02.02.14 - 12:55
    Posts: 2577 from 2003/2/24
    Actually your pretty much offtopic....
    Sofar only G5s with PCI-X and AGP slots are supported (PCI-X being backward compatible with PCI cards).
    The only PCIe based G5 that has beeen seen running MorphOS sofar has exactly 0 slots (mmm, well actually there might be some (PCMCIA-style ?) slot for AirPort and/or BlueTooth modules).
  • »02.02.14 - 13:21
  • vox
    vox
    Well I have a nice fat prob and that is that SAM460ex has no free PCI slots (need to use SATA controller) and is picky on gfx cards - just some X1600 and 4000HD or better needed.
    And that is certainly part of development path, Jah is no secret?
  • »02.02.14 - 13:22
    > G5 end model is only PCI-E model until SAM460ex support. Which cards can be
    Because of the required PPC ROM it will probably be (a subset of) those Radeon cards working in the PCIe PowerMac G5:
    - X6xx
    - X8xx
    - X19xx
    Not in the PCIe PowerMac G5 models as there are no PPC ROM versions of those cards.
  • »02.02.14 - 15:11
    > SAM460ex [...] is picky on gfx cards - just some X1600 and 4000HD or better needed.
    There will be more supported from the X1xxx series than just X16x0:
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=38&topic_id=9764&start=94
  • »02.02.14 - 15:17
