Toshiba dvd rom
    matt3
    Posts: 763 from 2004/2/10
    Has anyone had any luck using a Toshiba DVD ROM (SD-M1202).
    Thanks...
    Matt
  • »14.02.04 - 13:31
  • News Moderator
    News Moderator
    Darth_X
    Posts: 571 from 2003/2/10
    I have a Lite-on DVD drive that works fine in my Pegasos. I just plugged it in and it worked.. several other people have experienced the same result with their DVD drives.
  • »14.02.04 - 14:43
