Mac Minis and Apple Display Studio Monitor mistery
    WeiXing3D
    Posts: 327 from 2012/6/13
    Is there any difference in the way a Mac Mini G4 1.42 connects to an Apple Studio Display and a Mac Mini G4 1.5?
    I'm using with my G4 1.42 a DVI to ADC Adapter to connect the monitor and then a DVI cable from the adapter to the cpu; this wroks just fine.
    The mistery is that I just bought a Mac Mini G4 but this time the 1.5 silent update with 64Mb VRAM, and when using the same monitor setup, the monitor doesn't turn on.
    I tried the "new" Mac Mni G5 with another DVI Montitor (Sharp) using a DVI cable directly, without going through the DVI to ADC Adapter, and to my surprise it works fine.
    Do thsi two revs of G$ CPU connect in a different way? What do I need to continue using my Apple Studio Dsiplay with the G4 1.5?
  • »10.01.14 - 03:43
    Posts: 2555 from 2003/2/24
    The digital part of the DVI port might be broken quite common issue wth the minis.
  • »10.01.14 - 10:19
    WeiXing3D
    Not really in my case. Like I said I used the Mac Mini g4 1.5 with a DVI cable connected to a Sharp LCD monitor and it works just fine. It doesn't work with the Apple Dsiplay Studio that I'm using with the G4 1.42
  • »10.01.14 - 18:51
