Morphos 3.3 issue on powerbook 1085
    soviet
    Posts: 102 from 2008/7/2
    Hi today i got a powerbook 17" model 1085.
    Is on the morphos 3.2 supported hardware list.
    The problem is that i installed morphos 3.3
    but i can't get audio, the brightness keys and keyboard backlight keys do nothing, wifi dont work.
    I got lan working and 3d acceleration, but the rest of the features don't work
    Anyone having this issue? theres some way to fix it ?
  • »18.09.13 - 22:57
    soviet
    Tested on morphos 3.2 same as on 3.3 the indentificator is PowerBook5,5
  • »19.09.13 - 02:15
    soviet
    The touchpad works but on morphos 3.3. theres no icon on preferences, on morphos 3.2 the preferences icon appear and i can change options releated bizarre
  • »19.09.13 - 03:10
    Posts: 3336 from 2003/3/5
    You could've changed them, but they wouldn't do anything - your PowerBook does not have an USB touchpad and these settings are only for the last two revisions that provide raw sensor pressure readings via USB.
  • »19.09.13 - 04:26
    Posts: 611 from 2003/4/11
    Some extra features are definitely disabled currently because we didn't have the required PowerBook to verify them. We will try to fix this for the next 3.4 update.
    Please use our "Report Bug" button in the About MorphOS/Support tab section if you identify any issues.
    User reports are moved into our bug database after validation. Just reporting it here might get overlooked easily.
    Internal Wifi is not supported at all currently. There is a chance that this will change for a future update, though.
  • »19.09.13 - 07:27
    soviet
    Ok i fix a bug report.
  • »19.09.13 - 11:34
    soviet
    Theres any wifi pcmcia card i can get ?
  • »19.09.13 - 13:26
    soviet
    I can live whitout volume control keys and brightness but having no sound is a no go.
  • »19.09.13 - 13:48
    SoundSquare
    Posts: 1214 from 2004/12/1
    that's amazing (even if it had been mentionned before i think) news !
  • »19.09.13 - 14:20
    soviet
    Filled bug report crossing fingers wishing it work on the next morpohos release.
  • »19.09.13 - 14:51
    boot_wb
    Posts: 874 from 2007/4/9
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=9517&forum=3&start=4
    /Wolfmode
    [ Edited by boot_wb 19.09.2013 - 18:49 ]
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »19.09.13 - 15:48
    soviet
    Great the NetGear WG511T only 8 usd free shipping :P, if i only can get audio.
  • »19.09.13 - 17:39
    pampers
    Posts: 1073 from 2009/2/26
    Stupid question I know but I have to ask: do you have your volume up in wbstartup/mixer?
    MorphOS 3.x
  • »19.09.13 - 18:09
    soviet
    Yes is up all the way, also tried changing units and amplification on AHI but is a no go.
    When i boot the volume appears by default whit a red X like i have mute but moving it up all the way have no diference, i tried also connecting earphones and having the same issue
  • »19.09.13 - 22:37
    soviet
    I posted a bug report and one of the morphos dev team contacted me, he whas able to fix the compatibilty problems on this powerbook model, sound and brightnes control, very nice guy. Great support :D so the next release probably will include this fixes by default.
  • »25.09.13 - 12:50
    boot_wb
    That was quick!  :-)
    Glad to hear you're up and running, you seem to have been really unlucky with some hardware purchases.
  • »25.09.13 - 15:57
    soviet
    The new morphos 3.4 works great sound/brightness issues are fixed out of the box.
    :D thanks morphos team, i even can change to non native resolutions.
    Low resolutions tend to flicker.
  • »26.12.13 - 16:42
