Guide to install MorphOS 3.3 alongside with MacOSX?
    Phantom
    Posts: 381 from 2004/9/7
    I found (and bought) a PowerBook G4 (PowerBook 5,8) model at 1.67GHz with 1,5GB RAM and 120GB HD complete in box in order to run MorphOS at least, as the possibility to see an AmigaOS laptop is very rare now.
    Although, my first idea was to install MorphOS only, I decided to install MorphOS but keep MacOS X as well.
    I found a dual-boot guide on the internet (for MacMini), will this do the job for me?
  • »19.11.13 - 22:33
    Posts: 12557 from 2003/5/22
    > I decided to install MorphOS but keep MacOS X as well. I found a dual-boot guide
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=11&topic_id=8797&start=63
  • »19.11.13 - 22:56
    I have used the same information to set up dual boot PowerMacs.
    Its pretty much applicable to anything we use.
    In fact Kronos pointed out to me that with slight modifications it makes a great way to start booting on an ATA drive and then switch over to an unflashed PC SATA controller to finish.
    That has to be one of my most referenced documents.
  • »20.11.13 - 01:16
    Phantom
    Thanks for your answers.
  • »20.11.13 - 15:18
    Phantom
    Just another question arised. Is it possible after installing MorphOS, to upgrade MacOSX to a newer version from scratch?
  • »21.11.13 - 15:26
    Cool_amigaN
    Posts: 777 from 2011/11/30
    @Phantom
    If I may ask, how much did it cost you the purchase of the PBook? Was it in mint condition, battery ok etc? I am toying with the idea of trading the PMac over a PBook (mainly for reasons of portability and space) and I would know how much more would I pay for that.
  • »27.11.13 - 07:42
    Phantom
    Check AmiBay, it's very easy to find it. ;-)
  • »27.11.13 - 14:52
