Posts: 159 from 2003/10/24
Ok we are at it again. I've set up my printer under ambient prefs. I cannot print from MorphED, then I got some intructions to print from the cli. Well it did Nothing!!!!! just sat there like it was spooling and produced nothing in return. Yeah I've been told use a different app, ok fine but if it can't even print from the cli then what good will it do me? the following is what I used to print from the command line.
type sometext.txt > prt:
I have a HP Deskjet 695 and set it up as a 690-694 in prefs. And before someone tells me that thats my problem the 695 has no issues printing as a 690 printer in dos/windows/linux. Shouldn't be an issue with MOS IMO.
Any suggestions will be greatly appriciated and I will try just about anything to see if works.
--Mithalas
