iBook and Internet
    Opal
    Posts: 11 from 2013/9/27
    Hello, i can not go to the internet with my iBook G4.
    OWB shows failure n. 6 couldn´t resolve host name.
    And now ?
    Thanks.
  • »27.09.13 - 11:30
    Yasu
    Posts: 1724 from 2012/3/22
    Do you have the correct settings in prefs? Remember that the internal wifi doesn't work with MorphOS.
    My MorphOS blog
  • »27.09.13 - 11:53
    Opal
    What are the correct settings ?
  • »27.09.13 - 11:55
    defender
    Posts: 249 from 2011/4/24
    That, depends upon your Router settings. And of course how you want to
    connect to your router.
  • »27.09.13 - 12:10
    Posts: 1077 from 2004/9/23
    First the ehternet wire must be plugged in before (!!) booting.
    Afterwards open a shell. type
    ifconfig
    If it shows something like: inet 192.168.0.222, then DHCP is enable, but failed.
    Open network settings and check the field "router", remember the contents. Now swap to host and dns page and enter (or paste) the content as first dns server. Push save and you are done.
    If there is no IP, then open network and configure it manually. If you have a PC or OSX connected, just use the values it is using. Just change the last digit of the IP to avoid creating a dupe.
    Geit
  • »27.09.13 - 12:32
    Opal
    ok, but owb says failure 6 couldn´t resove host name.
  • »27.09.13 - 13:14
    SoundSquare
    Posts: 1214 from 2004/12/1
    ok what ? what have you tried/done so far ? what does ifconfig says to you ?
  • »27.09.13 - 14:06
    Opal
    thank you, now it works..
  • »27.09.13 - 14:11
