dualboot morphos default
    GMKai
    Posts: 257 from 2003/4/7
    I have a Powerbook running OSX and Morphos fine. It boots to OSX by default. I fail changing to boot Morphos by default. I changed in OF the boot-command rdnung to the dualboot guide id MZs Library. But all i getan id a grey screen.
    What can i do to avoid s the ALT-Key in each boot
  • »22.09.13 - 13:52
    boot_wb
    Posts: 874 from 2007/4/9
    Hi GMKai,
    That sounds as if there's a mistake in the boot-command (eg wrong partition number).
    It might be worth checking this bit again:
    To determine the partition number of the HFS boot partition type the following:
    dir hd:x,\\
    where x should be a number from 3 to n, depending on partition layout. If you see boot.img and bootinfo.txt files being listed, this is the correct one. Now type:
    setenv boot-command boot hd:x,\\bootinfo.txt
    replacing x with the partition number you just found.
    It might also just be worth checking that no typos have been made when inputting the boot-command using 'printenv boot-command' at the openfirmware prompt (eg mistaking colon for semicolon, forward-slash for back-slash, etc).
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »22.09.13 - 14:36
    Posts: 2205 from 2003/2/24
    Wasn't it possible to change that from OSX? IIRC I did it back then when Mac support came... haven't used dualboot anymore though.
  • »22.09.13 - 14:44
    GMKai
    Stange hing is
    manually entering the command works...any known sideeffects when auto-booting?
  • »22.09.13 - 15:34
    boot_wb
    GMKai wrote:
    Stange hing is
    Weird. Maybe 'boot-device' is also set and causing problems?
  • »22.09.13 - 21:32
    GMKai
    Boot-device and boot-file Are empty But automatic bootjing fails .
    I still getan an empty grey screen.
    Manually typing boot-command leads to Ambient.
    any other good boot-command?
  • »23.09.13 - 10:11
    imax
    Posts: 41 from 2004/9/20
    GMKai,
    MOS 3.3 do solve my problem.
    See may topic
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=8534&forum=3#92926
  • »24.09.13 - 07:36
    GMKai
    Before updating i Set boot-command ti "bootmenu"
    will See hat Lappen wich 3.3 ti getan Morphos the default
  • »25.09.13 - 04:50
