Flashed Radeon 9200 issue?
    Doffo
    Posts: 508 from 2010/10/14
    Yooo!
    For the longest time my flashed Radeon 9200 SE was not an issue and did everything quite well. Just a few days ago, after powering up the MDD, everything would come to a crawl and super slow. I figured maybe I overlooked something inside or maybe MOS installation became bad. Same issue happened once I booted into the MOS install, everything comes to a crawl after 2 minutes. I finally brought in a spare Mac 9000 Pro card in and everything is back to normal speed with no slowdowns.
    I wonder if this is the same issue others are having on their G5 macs on flashed Radeons? I am not saying all radeons are in bad shape but driver issues cause it to lag out and come to a super slow computer.
    Either way, Happy Labor Day!
    YUUUP!
  • »02.09.13 - 14:05
    According to what I have heard from Frank, the problem with Radeon 9800XT cards is the same whether a flashed card or a genuine Apple card is used.
    So I doubt it is an issue with the rom.
  • »02.09.13 - 21:26
    Tom01
    Posts: 186 from 2009/9/20
    Why are you using the 9200 SE, the 9000 PRO is better.
  • »05.09.13 - 09:40
    Get27
    Posts: 90 from 2004/8/23
    Hello,
    same here since MorphOS 3.0 with config below.
    Works well with 2.7
    PowerMac 3.5, G4 1.0GHz DP, 1GB ram, 80GB HD + NAS, Radeon 9600 128MB Mac, 1680x1050
    PowerMac 7.3, G5 2.3GHz DP, 4GB ram, 160GB HD + NAS, Radeon 9800 128MB PC, 1680x1050
    Amiga 500+, Vampire 500v2+, HxC Floppy
  • »05.09.13 - 20:03
    Doffo
    I am using the 9000 Pro now :) :) Just had it in there for the time being.
    YUUUP!
  • »05.09.13 - 20:47
    Yeah, I have two of those (@ only $15 each they are a bargain).
    R300 based cards are also pretty cheap now.
  • »07.09.13 - 17:27
    Get27
    Thanks MorphOS Team, PC flashed 9700 Pro (128k rom) works well with MorphOS 3.3 in my Mac G4 !
    EDIT 2013/09/21 : Works well with PC flashed Radeon 9500 (128k rom) and 9800 (64k rom reduced) too !!!
    [ Edité par Get27 21.09.2013 - 11:47 ]
  • »18.09.13 - 16:49
