Posts: 1116 from 2013/5/24
mmace wrote:
Hi guys, I'm still undeceided between a Mac Mini (quiet) and a Power Mac (been told they are loud, comp will be in lounge with my i7 PC)
Couple of questions about the Power Mac G4, if I find one with a Radeon 9000 Pro, is there anything else I need to look for? (it has 1Gb RAM, 1.25Ghz CPU, 160 & 120Gb HDD)
Will this be compatible?
It's £50 so a fair bit cheaper than buying a 1.5Ghz Mac Mini
Can I fit a new fan/fans/PSU to quieten it down?
if so, what should I be looking for and does anyone know of any UK stockists (or eBay) for what I'm after?
any help appreciated with this
Get a G5 then you won't have to put your heating on this winter. ;)
