Posts: 1116 from 2013/5/24
Kronos wrote:
Common issues with PowerBooks:
- faulty 2nd RAM socket on 15" models, 5.6, 5.4 and older can have this issue (5.8 uses different RAM, does not have the issue and even if it did can be maxed out to 2GB with just one stick).
If the PB your buying reports 2 working sticks of any size its o.k. (and likely to stay o.k.)
I've got a PB 5,8 and it does have this problem with the faulty 2nd RAM socket.
It worked for a while, then it started locking up whenever the machine was moved, then it just flat out refused to see any RAM stick inserted into the 2nd slot.
Now I just have 1GB in the first slot and it works fine.
