[Card Reader]: Volumes disappear
    noob
    Posts: 24 from 2012/10/17
    Hello Community!
    I am using MorphOS 3.2 on a MAC Mini G4. Whenever I use my card reader everything works fine. I can access the volumes and transfer data, but after some minutes the volumes disappear and a poseidon popup tells me "Warning: Dead Device". As I am still a MorphOS noob I do not know what to do?
    Please help me. I am happy about any information I can get. As it functions in general (for max. 3 minutes) I think it is all about the settings!? If you are so kind to answer to my question beare in mind that I am an absolute MorphOS noob without any Amiga experience. But I love MOS and step after step I am getting deeper into it. ;)
    Mac mini G4 Silent-Upgrade - MorphOS 3.2 registered
  • »10.08.13 - 13:13
    shaf
    Posts: 15 from 2013/6/11
    I suspect there's no enough power from the USB Port to keep the card reader working, does the same problem happen when running the Mac Mini with MAC OS.
  • »12.08.13 - 13:35
    SoundSquare
    Posts: 1214 from 2004/12/1
    i bet it doesn't : )
  • »12.08.13 - 18:56
    bash64
    Posts: 972 from 2010/10/28
    I have been having the same usb issues with mos 3.2.
    mos 3.1 did not do this.
  • »12.08.13 - 20:34
    noob
    I am a MOS only user! :)
  • »14.08.13 - 18:33
