Radeon 9600 xt Problem Visualization
    sabbate
    Posts: 110 from 2013/7/7
    Hi All,
    I can not understand why the images the texts and logos on the screen are not displayed well is a problem of graphics card?
    Hi
  • »02.08.13 - 09:53
    Posts: 3311 from 2003/3/5
    sabbate wrote:
    Hi All,
    How are we to guess what's wrong if you do not provide us with a screenshot?
  • »02.08.13 - 10:12
    Cego
    Posts: 738 from 2006/5/27
    take the other DVI output on your graphics card.
  • »02.08.13 - 10:19
    sabbate
    I have a dvi output and another that I do not know what
    hi
  • »02.08.13 - 10:28
    SteveE617
    Posts: 80 from 2013/1/26
    It's probably an Apple ADC connector.
    Steve E, BSOE, MIS
    PowerMac G5 | Dual 2.0 Ghz | 2 GB | 32GB CF | 9800XT
    AmigaOne x5000 | 8 GB | 1TB | Radeon 7770HD
  • »02.08.13 - 11:59
    sabbate
    ok you have to use that?
  • »02.08.13 - 12:39
    sabbate
    The problem is MorphOS no hardware!! sig!
  • »02.08.13 - 16:18
    Posts: 607 from 2003/4/11
    Are you at least able to make some photo screenshot of the actual problem ? It's hard to get an idea of the actual problem without it ...
  • »03.08.13 - 11:10
    sabbate
    I wait for the next release of morph, I hope will be soon!
  • »03.08.13 - 13:51
    sabbate
    pega-1,
    as soon as I can I get a picture
    hi
  • »03.08.13 - 15:44
