Official Freescale MPC5200B Errata for ATA etc.
    SKOLMAN_MWS
    Posts: 107 from 2006/10/24
    http://www.freescale.com/files/32bit/doc/errata/MPC5200BE.pdf
    MorphOS support DMA UDMA mode for ATA on EFIKA?
    _
  • »24.07.13 - 11:30
    Posts: 12557 from 2003/5/22
    > MorphOS support DMA UDMA mode for ATA EFIKA?
    AFAIK no, as the UDMA state machine of the MPC5200B is buggy. And using BestComm DMA as an alternative was tried but entailed other problems (there were statements in the MorphOS mailing list in 2010 from laire and Bigfoot about distorted graphics in software-rendered Quake).
  • »24.07.13 - 12:41
    > ATA DMA support in the current Linux driver
    BestComm DMA may work reliably under Linux, but as said in my previous posting, the MorphOS Team tried to implement it but said they had failed to get it to work properly. That was in 2006 or 2007.
    You can see the distorted Quake graphics in BestComm mode there:
    http://bigfoot.morphos-team.net/test/efika-quake-1.png
  • »24.07.13 - 14:09
    connor
    Posts: 650 from 2007/7/29
    Is it a Quake only problem? MOS offers much more possibilities than running Quake. So if a very little amount of programs or games have problems but the majority not - then this little amount should not be considered.
  • »02.08.13 - 14:56
    Posts: 1095 from 2004/9/23
    I had a DMA enabled version of MorphOS even before first release and it caused bit errors on Harddrive, which are AFAIR triggered by other DMA operations.
    Also a friend (he may correct my memory here) of mine did some testing with GFX, HDD wrting (DMA enabled) and Network at the same time on linux, with the same result of randomly false bits.
    Geit
    [ Edited by geit 02.08.2013 - 21:02 ]
  • »02.08.13 - 15:10
    connor
    I see. So the board itself is flawed.
  • »02.08.13 - 15:30
    Henes
    Posts: 507 from 2003/6/14
    "DMA assisted PIO"
    Yeah right... Call it DMA if you want. Even if the technic itself is really a cool idea, this doesn't change the fact this is PIO for the rest of the world.
  • »02.08.13 - 15:33
    analogkid
    Posts: 722 from 2004/11/3
    connor,
    No, "just" the 5200B SoC.
  • »02.08.13 - 18:17
