Posts: 1116 from 2013/5/24
Doffo wrote:
It doesnt have the issue on a normal HDD on my 2nd Mac Mini. Was thinking maybe because of the OC to 1.75ghz might be causing it to glitch. I can just leave the player going and it randomly jitters. Either way, ill have to tinker with it some more.
I get a similar problem on my Powerbook with an normal HDD. Adding 600 buffers to the PFS partition and 1000 to my IceFS partition helped a bit as did increasing the cache to full in the system preferences and choosing Least recently used option with Read Ahead sectors to 64 on both partitions. I left the HFS partition untouched with no read ahead.
I have no scientific basis for this working but it did seem to help so far. Could be placebo though I guess.
I chose 600 for the buffers on the PFS3 System partition as I have a vague memory of Piru saying it was the optimum number for PFS3.
No harm in you trying the same to see if it helps I suppose.
