powerbook g4 bugs
    kickstart
    Posts: 227 from 2009/4/28
    I have a powerbook g4 1,67ghz with ati 9700 64mb and my fault are the following:
    trackpad dont work under morphos, i need a usb mouse for use it.
    keyboard backlight dont work under morphos.
    function keys for change volume, brightness... dont work under morphos.
    All of this is with the ultima release (morphos 3.2), any ideas?, thanks.
  • »24.07.13 - 14:22
    Intuition
    Posts: 1113 from 2013/5/24
    Try a fresh install without the Pack Ultimate.
    I have the same model but with 128mb vram and everything works perfectly.
  • »24.07.13 - 19:17
    Krashan
    Posts: 1107 from 2003/6/11
    Ultimate Pack is not an official release so everything can happen after installing it. If you have any troubles, contact Ultimate Pack author.
  • »25.07.13 - 03:44
    Posts: 3274 from 2003/3/5
    Does the same apply when you boot from the MorphOS CD?
  • »25.07.13 - 06:28
    kickstart
    @all
    Sorry for my typo error, i talk about the ultimate morphos release, nothing to do with ultimate pack or whatever.
    Thanks for the answers but the powerbook have a fresh morphos 3.2 install, booting from the cd trackpad, backlight... doesnt run.
  • »25.07.13 - 15:53
    Intuition
    Do they work with OSX?
  • »25.07.13 - 16:29
    kickstart
    @intuition
    Yes under osx trackpad, backlight... runs ok.
  • »25.07.13 - 16:58
    Apple trackpads are pretty dreadful devices anyway.
    I just carry a mouse.
  • »25.07.13 - 17:04
    @kickstart
    That is pretty interesting. Would probably be best if you tried to catch me on the #morphos IRC channel after the weekend.
  • »26.07.13 - 06:07
