Posts: 972 from 2010/10/28
Finally solved. Here is the contents of the wirless.prefs file in sys:prefs/env-archive/sys/ folder:
update_config=1
network={
scan_ssid=1
ssid="my hidden ssid"
psk="my wpa password"
The laptop now finds my home network on boot.
The unofficial knowledgebase is now updated with the correct fix.
http://bettyboopdatabase.0usa.com/mos/mos.html
[ Edited by bash64 18.07.2013 - 01:11 ]Mac G5 ISight 21" 2.5 gb of ram 233gb hd matshita dvd-r uj-846
