Problem Boot Morph Mac 7,3 G5
    sabbate
    Posts: 110 from 2013/7/7
    Hello everyone, I bought a G5 7.3 model I just do not charge me morphos to boot from white screen, you have any suggestion? :-(
  • »16.07.13 - 12:20
    SteveE617
    Posts: 80 from 2013/1/26
    Which video card do you have installed?
    If you have an NVIDIA video card, MorphOS will hang at a white screen.
    Steve E, BSOE, MIS
    PowerMac G5 | Dual 2.0 Ghz | 2 GB | 32GB CF | 9800XT
    AmigaOne x5000 | 8 GB | 1TB | Radeon 7770HD
  • »16.07.13 - 12:29
    sabbate
    You're right, I have a nvidia, I thought I had a ati thank goodness that I have preserved
  • »16.07.13 - 12:50
    sabbate
    the ones I have are all agp :-(
  • »16.07.13 - 13:14
    sabbate
    I bought a 9600 xt hope that it works, however I agp 8x slot :-)
  • »16.07.13 - 13:45
    Jambalah
    Posts: 820 from 2008/3/30
    Hi Sabbate!
    Keep calm & MorphOS =D
    If your graphic cards are all AGP I guess there's no problem at all! As I've read on AmigaNews (I will post an answer there too ;-) ) you don't need a PCI-E video card (but... why a PCI-E?!? I hope you din't buy a late 2005 model... ) you need an AGP Mac Ati Radeon to start.
    Give an eye here:
    http://www.everymac.com/systems/apple/powermac_g5/index-powermac-g5.html
    7.3 G5 has a 8X AGP slot so you shouldn't have any problem but check your G5 model anyway.
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »16.07.13 - 13:53
    sabbate
    si m sono accorto dopo che ho uno slot agp, caspta su ebay le cfre per una radeon sono folli ma fortunatamente me ne sono aggiudicata una con 30 euro ciao e grazie :-)
  • »16.07.13 - 15:26
    sabbate
    Ok, I have buy ati radeon 9600 xt agp 8x only 30 euro :-)
  • »16.07.13 - 15:56
