Weird USB Issue...
    pan1k
    Posts: 147 from 2009/1/20
    Hey guys..
    Whenever I insert a USB stick into my MDD G4, the volume name shows up, but when I click on the icon on the desktop, the wrong volume appears. I have tried two different sticks, formatted it on a Mac and under MorphOS. Same Volume appears.
    Any ideas? Even going into the shell and typing the name of the USB drive will get me the wrong volume.... :-?
    MacMini 1.5Ghz / Amiga 4000T Cyberstorm 060, 132MB RAM, Cybervision 64/3D, XSurf-III, MP3@64, Buddha Flash / Amiga 1200 GVP 030, Subway USB, 32MB RAM
  • »13.07.13 - 05:48
    bash64
    Posts: 974 from 2010/10/28
    What file system did you format with?
    Some thumb drives are hard coded for fat32.
    Formatting them as NTFS might result in strange things happening.
  • »13.07.13 - 06:32
    pan1k
    I tried FAT and SFS... whenever I click on the icon it opens a HD's partition...
  • »13.07.13 - 06:56
    Posts: 604 from 2003/4/11
    Maybe check in a shell with the info command if it is properly mounted or collides with an already mounted volume ....
  • »13.07.13 - 07:11
    pan1k
    That was it. I have TWO volumes named untitled. If I change them in HD Setup will it harm the partitions? They are both HFS partitions.
  • »13.07.13 - 21:59
