Posts: 2077 from 2003/6/4
tokai wrote:
4. The Peg2 Motherboard has also connectors on the back, but u can connect the frontconnecters to the motherboard too. But most cases have a small problem here the cables are too short, but should work nicely with some longer extension cords.
Take care if you take an extension cable. It *must* be drilled and have a low resistance and should be as short as possible. Otherwise the data might get corrupted.
