SoundBlaster Live on PowerMac MDD
    CountRaven
    Posts: 566 from 2007/12/10
    Hello folks. I put a SoundBlaster Live on my PowerMac G4 MDD. Should I download and install the driver form somewhere in order for this to be listed on AHI preferences? It is not listed right now :(. Thanks!
    [ Edited by CountRaven 08.07.2013 - 15:03 ]
  • »08.07.13 - 10:14
    Jambalah
    Posts: 820 from 2008/3/30
    Hi again =)
    Did you check if that is a right emu10k SoundBlaster? MorphOS has drivers for this card yet and since you didn't find inside audio preferences makes me think that is a wrong card...
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »08.07.13 - 11:30
    CountRaven
    Ok it seems that the card was not put properly, I pushed it a little on the slot and now all the drivers -Emu- appear, but no matter which I select the sound comes corrupted out of my spekaers / ehadphones. The card is a CT4830 model. Any ideas?
  • »08.07.13 - 12:48
    Posts: 2564 from 2003/2/24
    Do you have other PCI-cards installed ?
    The SBLive! is known as a rather "dirty" design, so just putting it in another slot might improve things.
    Either that or you knackered it by running it half plugged in  :-(
  • »08.07.13 - 13:58
    Krashan
    Posts: 1107 from 2003/6/11
    @ CountRaven
    the sound comes corrupted out of my spekaers / hehadphones
    In what way it is corrupted? It may be AHI configuration issue.
  • »08.07.13 - 15:21
    CountRaven
    Moved it on another slot and now it works, which driver is the best to use? The plain Emu, the Hifi or the 7.1 one?
  • »08.07.13 - 16:20
    CountRaven
    Strange noisses, clips bibs and bops between the ussual sound, have not touched anything to AHI. But as I said it now works ok.
  • »08.07.13 - 16:23
    So probraly just some PCI-interrupt nonsense acting up  :-o
  • »08.07.13 - 18:43
    Posts: 12537 from 2003/5/22
    There's just one driver which provides various modes. If you have the appropriate audio equipment you can use 7.1 mode, else I recommend HiFi mode.
  • »08.07.13 - 19:04
