scanners on mac g5 and usb issues also
    bash64
    Posts: 977 from 2010/10/28
    I am using two identical systems, one a powerbook g4 and the other a mac g5 2.3ghz.
    Same software installed by Grunch.
    The scanner I am using is a Epson Perfection 1640su , the same scanner the author of SCANdal uses.
    It all works in on the G4.
    The G5 locks up.
    I cannot open Poseidon with it plugged in.
    I cannot launch anything out of the control panel after clicking on USB.
    I have to reboot.
    This scanner gives no issues on a G4 setup.
    I am guessing it is something to do with the power being drained.
    The scanner, obviously , has its own power source.
    Exact same driver and OS on both machines.
    Sometimes I can get poseidon up and it shows the scanner but this is rare.
    I experience lockups mostly.
    [ Edited by bash64 04.07.2013 - 11:01 ]
  • »04.07.13 - 12:59
    bash64
    p.s. Tried all of the ports on the G5.
    No luck.
  • »04.07.13 - 13:01
    bash64
    Powerbook G4 just did the same thing.
    I have tried a different cable.
    G4 looks ok, not sure. It is working.
    G5 still locking up with a different cable.
    [ Edited by bash64 04.07.2013 - 11:18 ]
  • »04.07.13 - 13:12
    bash64
    The G4 is having lockups but will ,after a reboot ,scan.
    The last message from poseidon before locking up on the G4 is 'Warning cdcacm.class Unable to load the modeswitch data file..."
    BTW: Even though poseidon is locked up I can still launch SCANdal on the G4 and scan a color document.
    Very odd.
    Did Poseidon have any changes for mos 3.2?
    [ Edited by bash64 04.07.2013 - 11:29 ]
  • »04.07.13 - 13:27
    zukow
    Posts: 661 from 2005/2/9
    Sorry, i'm in the hospital now without any morphos machine. I should leave within 1.5week and i'll look into g5 pproblem . I can suggest deleting posidkn prefs in case of any odd situations.
  • »05.07.13 - 06:02
    bash64
    Thanks. I thought you were just the printer guy.
    :-D
  • »05.07.13 - 07:29
    boot_wb
    Posts: 874 from 2007/4/9
    Zukow!
    Hope you're on the mend, and there's still some sunshine left for you when you get out of hte hospital.
    Best wishes, and a virtual bag of grapes:
    Rich
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »05.07.13 - 08:53
    bash64
    I have a NEC 5 port usb pci card from my old quicksilver.
    Can I plug that into my mac g5 2.3ghz dp system?
    The slots are 64bit.
    According to wiki pci-x is backwards compatible with 32bit cards.
  • »05.07.13 - 11:51
    Posts: 12558 from 2003/5/22
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=9321&forum=11&start=1
  • »05.07.13 - 12:34
    bash64
    Boy, that sucks.
  • »05.07.13 - 14:53
