Installing Morphos On G5 issues
    Rats
    Posts: 33 from 2013/1/22
    Hi I have recently purchased a PowerMac G5, PowerMac7,3 and I am hoping to get it working for Vintage Computer Fair GB.
    I have been trying to boot from Morphos Cd from a freshly burnt CD. It reads fine when inserted and appears in the startup menu when I press ALT during startup.
    The Issue is when I try to boot from cd the screen go's gray and the fans start speeding up a lot and it just hangs.
    I have tried to get it working doing the following:
    [list]-Replacing the DVD with one I know works well
    -Burning Cds to different formats to see if they work
    -Tired to boot of USB but that was a headache as the USB disk was not showing up -on the open firmware
    -Tried formatting a partition so I can boot from it
    -Pram reset
    -Firmware updates (all up to date)
    [/list]
    Any advice you can offer or tips for getting this running as I have not run into this issue with MacMini or PowerMac G4. I also checked the Model numbers to check I had the correct model which I do.
    [ Edited by Rats 01.07.2013 - 17:02 ]
  • »01.07.13 - 14:01
    Yasu
    Posts: 1724 from 2012/3/22
    Stupid suggestion maybe, but is the gfx card a radeon or geoforge?
    My MorphOS blog
  • »01.07.13 - 14:29
    Rats
    Thanks for asking. I just check and it is indeed geoforge. I have just ordered a radeon from ebay :D and with delivery time it should arrive a day before the show.
  • »01.07.13 - 15:32
    Posts: 2209 from 2003/2/24
    And that ordered Radeon is Mac version for sure? :)
  • »01.07.13 - 15:34
    Rats
    yeh i looked up on the morphos site compatible cards and I brought ATI Radeon 9600 128MB Graphics Card PowerMac A1047
  • »01.07.13 - 15:42
    Intuition
    Posts: 1116 from 2013/5/24
    I didn't even bother trying to install from CD on my G5 as I'd read a few complaints from others.
    Your best bet is to persevere with installing from USB.
    [ Edited by Intuition 01.07.2013 - 18:49 ]
  • »01.07.13 - 15:48
    Yasu
    I think my G5 works just fine. But maybe a dual boot is an attractive solution as well.
    My MorphOS blog
  • »01.07.13 - 16:29
    Intuition
    So does mine but I have no idea if it boots from CD or not as I didn't try. Installation from USB went smoothly once I guessed the correct port number in OF.
  • »01.07.13 - 16:33
    Yasu
    Ok, I misunderstood what you meant. I did it from CD without problems. Just following the written instructions.
    My MorphOS blog
  • »01.07.13 - 16:52
